see the new Altima SE-R??
SnakeEyeSS
anyone see the ad in the new Motor Trend? looks like a decent car. mainly how the Engine almost is up to the Maxima's(265HP) power rating at 260. the way the Maximas fly, I bet those SE-R altima's will be monsters. dosen't look half bad either.
I hope a magazine compares this with a GTP Comp-G, would be an interesting read, IMO
I think they bumped the 3.5S from 240-245 also.
The altima is a sleeper. It doesn't look like much but it does haul. I tested a 04 this summer and was impressed by the handling and the power. This se/r must rock. I think it has 18 inch wheels I think 225/45 or so. The interior was kind of cheesey but was to be changed for 05 The seats were comfy and it fit me great. But my old bomb keeps running so haven't bought one yet. Maybe this will be the one :nono: Cant wait to test one out.
  • 1 month later...
Let's hook up end to end, and see who wins!! just kiddin.. look's like a solid car!
-J's 92
Cool :D Just let me sneak some sand under all four of your wheels first just to make it more fair :D Since I live just up river from you I'll run ya in the 1/8 mile.or on the 494 corridor. :chevy: But I'll have to get one first.
    Sothpaw27
    Sothpaw27
  • Who's Online   4 Members, 0 Anonymous, 825 Guests (See full list)
