Electronic AC Controls
Hey all,
It seems that my electronic AC swtich is going out. When the AC is on everyonce in a while the air will start to warm up for a bit and then all the sudden get cold again. I figured since I have a leaky evaporator, it just needs a charge. Once we got some gauges on it all the pressures were normal.
Has anyone ever had to replace one of these switches? How much does it cost? How expensive are they?
Does anyone have any theories about what else this might be?? Maybe thermostat or something??
Thanks
Not sure about 94, but I've heard that some of the newer models were experiencing blend door actuator/motor failures. Might be something to look into first.
    Brendan C
    Brendan C
  • Who's Online   5 Members, 0 Anonymous, 1,164 Guests (See full list)
