Bigger tires
What the deal with bigger tires, I have an '04 D/A(LLY) CC 4X4 and I'm thinking of bigger tires and was wondering what it will do to my mpg. Right now I've only got about 2000 miles and will be pulling a 22' enclosed car trailer. So far I've got 18-19 with out the tariler and on a short pull (50-60 miles) I averaged 16 with the trailer. I've done no mods so far either.
i also own a 2004.5 gmc 4x4 cc d/a have approx 6000miles
on it.i went on size bigger with tires did not want to trim any
thing i went with 265-75r16 goodyear wrangler at/s load e.
i noticed a decline in milage about 1 mpg at highway not much
anywhere else i tow a 9000# trailer and get 13-14 mpg at 65-
70 mph.i did notice though i tracked my mile an hour by a gps
with the new tires and at 70 mph im going 71.5mph according to
the gps so im thinking the stock tires are programed to show driving
faster but your are going slower dont know it seems that way but
anyway if you have the painted front lower valance and its a gmc
it hangs way down on the sides and 285s will rub without triming
my 265s are just about 1/4 to 1/8 close to it on turns but i did
not turn the torsion bars it looks great the way it is.
good luck :mad:
I'm heading out on a 1800 mile round trip this weekend I'll see what this thing does real world before I change anything. Thanks for the input.
