New Z06, 7.0L 500hp
Chris97K1500
Well, you all might already know this, but a guy at Laguna Seca Raceway (however you spell it) got a pic with 7.0L stamped on the block. He also got a block number which does not match any of the previous block numbers. Also, a carbon fiber intake cover was on the engine. This very well could be next Z06 engine. There's alot of talk, hopefully we'll see it for real. A 500hp, 3000lb, 427 would be one heck of a supercar! What a supertruck the SS Silverado could be with a similar engine! Chris
That would be sweet. Not taking away from the current Silverado SS, but a RC SB RWD with a 7.0L 50hp LS2 V8 and a six-speed......Look out Ram SRT-10. :mad:drivings.gif
Yea, this is something we discussed on the ZR-1.net for a while.
I've been a Corvette fan for years and I'm split between two feelings on this car.
1) 7.0L is absolutly insane. Nobody in their right mind would put gas in a car like this. 6.0L DOHC is the only way to go.
2) A DOHC Corvette would be another ZR-1. The ZR-1 is special and shouldn't be duplicated. Go with the 7.0L rod motor....
Guess at the money that I make its not gonna matter anyhow.
The rear meats on that thing are HUGE! Add another 100 hp and the pumpkin will barely fit between them??? :flag:
I an mot fond of the read brake "ducts" that seem to take away from the flow of the lines on the car, but with 700 hp on tap, I don't think anyone will notice, even IF they can get their vision to focus fast enough! :crazy:
For a while I thought they were gonna go 3-valve heads on the 7.0. Ya never know though, that motor might be a freak!!
B. CYLINDER BLOCK: Part Number: 12571246 (GM)
B.1. Cylinder Block Material: Aluminum B.2. Cylinder Bore (Max): 105.3mm (4.15”)
C. CYLINDER HEAD: Part Number: 12578452 (GM)
C.1. Cylinder Head Material: Aluminum
D. VALVE SYSTEM:
D.1. Number of Valves per Cylinder: D.1.a. Intake: 1 D.1.b. Exhaust: 1
D.2. Valve Head Diameter (Max): D.2.a. Intake: 56.0mm (2.20”) D.2.b. Exhaust: 41.0mm (1.61”)
E. INTAKE PORT DIMENSIONS:
E.1. At Inlet Manifold Face (Max): E.1.a. Height: 62.2mm (2.45”) E.1.b. Width: 36.0mm (1.42”)
E.2. Intake Port Work Allowed (Yes or No): No F.2.a. Depth from Face:
F. EXHAUST PORT DIMENSIONS:
F.1. At Exhaust Manifold Face (Max): F.1.a. Height: 35.1mm (1.38”) F.1.b. Width: 42.5mm (1.67”)
F.2. Exhaust Port Work Allowed (Yes or No): No F.2.a. Depth from Face:
L. INTAKE MANIFOLD: Part Number: 12569011 (GM)
L.1. Port at Cylinder Head Face (Max): L.1.a. Height: 59.2mm (2.33”) L.1.b. Width: 32.0mm (1.26”)
L.2. Intake Manifold Volume (Max): 5.9 Liters
L.3. Throttle Body Bore Diameter & Part #: 90.0mm (3.54”) ETC / 12570790 (GM)
L.4. # of Throttle Bodies: 1 L.5. # of Butterflies per Throttle Body: 1
L.6. Intake Manifold Material: plastic L.7. Manifold Pieces: 1
L.7. Intermediate Port Matching Allowed (Yes / No): N/A L.8. Depth from Intermediate Face: N/A
L.9. Intake Runner Port Matching Allowed (Yes / No): Yes L.10. Depth from Mounting Face: 1”
    Sothpaw27
    Sothpaw27
  • Who's Online   4 Members, 0 Anonymous, 825 Guests (See full list)
