egde-juice w/attitude question help
edge-juice with attitude question
i have a 2004.5 d/a cc 4x4 my question is that does
edge give you that much increase in power and torque
im seeing on stage 5 125 hp and 350lbs torque is that true
also they are stating that no problems with allison but in 5th
gear slippage just lock out and everything else holds up with
that much power. is it that hard to remove when taking to dealer
or should you worry about just sounds to good to be true.please
help also they are saying exhaust giving good numbers also any
luck out there thanks :mad:
The only downside with the Attitude is that it is installed in your cab. If you go in for service and a GM tech sees the Attitude - he/she could raise a flag! Other than that, the Juice is everything it says it is, and more.
I have AutoMeter pyro and boost gauges mounted on my pillar - anytime I go in for service I’m asked why they are there. I can easily brush it off by telling them that I pull heavy loads. The Attitude is a Juice product - meaning that it goes hand in hand with the Juice module. To me, that would be a gamble
You're on the borderline when it comes to 125HP and limping the Allson. I haven't really limped mine at 125. It's been anything above 125 that limps mine in 5th.
By the way, the installation and removal of the actual Juice module is really, really easy
You won't regret the Juice!
    bellssn690
    bellssn690
  • Who's Online   6 Members, 0 Anonymous, 805 Guests (See full list)
