Hello!
ouryukonxl
Thanks for a great site! Found it to be very helpful and informative. Picked up a 2000 Yukon XL last year to haul the kids around. So far I have changed the intake and exhaust. It runs real nice. Again, thanks to all. :mad:
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
