President Bush has done it.
99Silver6.0
But when you think about it though.... Bush didn't un-employment-ize them, we who voted did! :thumbs:
What I really want to see is the look on the faces of those treasonous Rock Stars who did that rock against bush thing. I hope they soiled themselves. :D
