Yikes! my brakes!
Well, the other day I had to make a panic stop.  An old old old lady pulled out in front of me while I was going 45mph.   And well I almost ended up in the d*mn ditch!  Apparently the mechanic told me that my brake pads had wore totally uneven and weren't near aligned.  So the left front disc brake grabbed, right didn't and I tried with all my might to hold onto the steering wheel but it broke my grip and hurt my arm.  It fully cranked the wheel!  Scared me shitless it did.  Then the old lady yelled at me and said I was a wreckless driver? .....45 in a 45 is wreckless drivin?  Anywho, I told her well, umm nothing nm heh heh heh.  I also had my brakes bled and new cylinders in the drums put in.
What do the cylinders in the drums do?
Thanks
Scary
If it was the left front,your problem wasn't a cylinder or a drum.On front brakes you should have calipers and rotors,the back brakes have cylinders and drums.
Your problem could be a few things.
1)Pads wore down and the rivets are  clutching the rotor.
2)Faulty caliper
3)Bad pressure differential valve
4)Who knows?
My 2000 ZR2 has 4 wheel antilocks and they will still lock up so it can,does and has happened.
(Edited by yZR2k at 6:13 pm on Feb. 6, 2001)
    JimmyB4
    JimmyB4
  • Who's Online   5 Members, 1 Anonymous, 560 Guests (See full list)
    • Point of the post sir was that while both wages and cost are rising EVERYWHERE; the cost is rising faster EVERYWHERE than the ability to buy EVERYWHERE. We're not going down the location rabbit hole. I'm aware of what economic migration is. I've lived in four states including Texas.   It's what "Purchasing Power" means.   I'm not telling you what I think. I'm telling what the government, your government, data shows.   It wasn't an argument. It wasn't a suggestion. It was a statement of FACT. You are absolutely entitled to your own opinion. Your not entitled to your own facts. If you and I were, they wouldn't be facts.    fact /făkt/   noun Knowledge or information based on real occurrences. "an account based on fact; a blur of fact and fancy." Something demonstrated to exist or known to have existed. "Genetic engineering is now a fact. That Chaucer was a real person is an undisputed fact." A real occurrence; an event. "had to prove the facts of the case." The American Heritage® Dictionary of the English Language, 5th Edition • More at Wordnik   If you'd like to disagree call your Senator or Representative and let him know his departments are in error. But you and I? We are not doing this.
    • Probably a one and done post, but do you have a CEL on the dash? Was having issues with my transmission, fortunately only a week, and it turned out to be the transmission harness. Valve body was in good shape, so new harness with all the sensors attached, new fluid, and filter. Seems to have worked so far?
    • Two interesting tidbits of information which are NOT related were just released.   One, regarding the possible thrust bearing issues / engine failures with the 3.0. Demonworks just did a segment in which they believe they may have found "a" or "the" cause of thrust bearing failures: A missing thrust bearing. If the engine doesn't have all its thrust bearings from the factory, the missing bearing can cause extra play which ends up destroying a nearby thrust bearing which then sends metal through the engine.       Of other importance, Lake Speed Jr released some interest information regarding oil weight selection for the 3.0. Comparisons of:   AcDelco 0w20 Dexos D Mobil 1 ESP x2 0w20 Dexos D Mobil 1 ESP x2 0w30 Mobil 1 ESP x4 0w40. Mobil Delvac 5w40   Spoiler alert: The Mobils are PAO Ester -base and the ACDelco is a Group III base. Mobil shows lower wear in their tests for similar weights. Additive packages between 20-30-40 weight ESP's appear to be the same, but only 0w20 is Dexos D licensed. Wear is even more reduced with 30 and 40 weight ESP although all perform very well and resist shear and provide very similar viscosities within temperature operating ranges in the 3.0.   There are even more surprises, so just go watch it.
    • Hello Guys I'm new to the form,         I just put a 7-inch Rough Country lift on my 2016 GMC Sierra 1500 with the 5.3 and I also put a Borla exhaust on it. But I noticed when I'm in park or in neutral and then I rev my truck up really quick there is a bad click noise and I think it's coming from the motor somewhere. Anyways I got a video of it I will attach below I was just wondering if you guys think its rod knock or lifter tick or something like that because I know the AFM kind of made the lifters weak on these trucks.       Thanks!!!!! RIP - Chevy 5.3 IMG_6043.mov
    • We’ll have to agree to disagree. I didn’t experience or know anyone who had a decent car after 100K miles in the 60s through the 80s that were daily commuter vehicles. Unless they were collector vehicles. Of course things cost more due to inflation. But we also make more money. The biggest money drains these days are things people think they need today versus what we require back in the day. Like cell phones and internet as examples. Another example is where you live. Cost of living varies from state to state. I would need twice the money to live in NJ vs Texas in retirement. The car you recently purchased was less than my first car with inflation at 3000$ in 1973. I didn’t have air, electric windows, cruise etc. Purchasing power is equivalent, you just have to do the research.
