wild country xtr tires
do any of you have these tires on your truck? i was originnaly looking at the bf goodrich all terrains, but then i saw these tires. i really like the tred on them lol. the bf's were 160 and the wild countrys were 120. so are the bf's worth the 160, or will i be happy with the wild country's. thank you
My father in law has those he is a small tire dealer. He sells out of garage in small town. He has them on his 2000 dodge 3/4 ton. Ill ask him when i see them in few weeks.
I put the Multi-Mile Wild country on my wife's 02 Yukon XL. The factory Wilderness were shot at 36k. The new tires ride great, hold in the wet stuff and have some grip. My only complaint would be that they are pretty noisy on the road, but I guess it is to be expected with the agressive tread. I got my 4 for a 100 per at a small dealr down here in Texas.
Do you mean the TXRs? If so I've had them on 5 trucks. I really like them on the 1500 series trucks but not as well on my 2500HD. On my 1500s thay ran about 50K,and had great traction till the end. On my HD they have about 12K on them,if they run to 25K I'll be happy. I think the tread compound is too soft for the weight of the HDs,so this will be the last set on my current truck. I'll probably go to the Toyo M55s next time.
sorry, i meant the txr's. yeah i like this tire too, i think ill go with this one, they will be going on my 96 gmc sierra 1500 4wd. hope im happy with them. thanks everyone
    CaptainDad
    CaptainDad
  • Who's Online   5 Members, 0 Anonymous, 487 Guests (See full list)
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
