I WANT INFO NOW!!!!!
SnakeEyeSS
we used to have all sorts of infos about future trucks floating around. I haven't heard anything about the next gen GM full-size trucks in a while?
How much power? what kind of engineering advancments?
Oh, and BTW,m if you guys haven't seen the Colorado SS concept(400HP LS6) check out the gminside news truck forums. They they give it the green light I will pre-order one!!!! :(
    Policeoff01
    Policeoff01
  • Who's Online   3 Members, 0 Anonymous, 784 Guests (See full list)
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
