NASCAR to utilize impound procedure in 2005
Elwood
November 15, 2004
DAYTONA BEACH, FLA. -- After tinkering with the Nextel Cup Series points race in 2004, NASCAR officials have decided to implement - at least on a partial basis - a post-qualifying impound procedure in 2005.
In a move that will all but eliminate "Happy Hour" practice sessions at more than half of the races in 2005, series officials now will impound cars following qualifying and post-qualifying inspection. During this period, teams will not be permitted to work on their cars unless given special exemptions by circuit officials.
The measure will affect all 43 cars until race day.
"We are still in the process of getting more tracks to commit to this procedure," NASCAR Nextel Cup Series Director John Darby said. "We appreciate the cooperation of our track operators to assist us in delivering cost-saving measures to the team owners."
Some of the costs that will be reduced involve labor, tires, oils and components.
Another byproduct of the new format is that the two 45-minute practices the day following qualifying - commonly known as "Happy Hour" - have been eliminated.
Like the point system change, I think most people will say it sucks and "Why can't NASCAR leave well enough alone?, But after '05 people will war up to it and start to like it. So it's tough to have an opinion on it right now. :D
I like the impound rule too. I think it's pretty cool.
As for the points, I was skeptical at first, but once I got a better understanding of how they work, and then saw it in action, I like it alot.
