MyGMlink.com... Have you been there?
ManyCamaroz
I was poking around on the puter a couple of weeks ago and stumbled onto the mygmlink.com website. I registered, entered my vehicle VIN numbers and found out I had 2 recalls on my Eldorado. It's a pretty good program... Check it out!
I had a problem logging on to the website several days after registering. I sent an E-mail to support, they replied they would promptly address the problem. Several days had past and I had not logged in and see if the problem was resolved. Having not attemped to log in they sent me another E-mail because they had not heard a reply back from me. They even called me to ensure my problem was fixed. The problem was fixed and for my trouble they sent me a gift certifcate for a free oil/lube change at any GM dealer nationwide.
Is that service or what? :banghead:
I wonder if FOMOCO would do the same?
I registered so far great customer service I too had a slight problem. Being mine was used vin and name were diff. one quick email and it was done. no oil change though :banghead:
    Policeoff01
    Policeoff01
  • Who's Online   4 Members, 1 Anonymous, 745 Guests (See full list)
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
