Removing scratches / key marks yourself
Daubs
Some jacka$$e$ keyed EVERY door on my new 2004 2500HD this summer (I'm chief judicial officer at a high school...so I'm always giving people bad news). Anyway, I debated what to do. Didn't want to spend the $$$ to get her repainted and just have someone re-key it. So I did a little reading, talked to some friends and came up with a plan that worked well on all but the deepest scratches.
Items needed: 2000 grit wet sand paper / rubbing compound / Meguires swirl and scratch remover / cloth towels.
1. (this is the scariest part, especially on a new truck), get the 2000 grit sandpaper and wet her down. Take small corner and rub ever so gently with your index finger in a circular motion. Go slow and light until you can't see or feel the scratch. Caution, it's going to look like a$$ when you do this, but be patient...it will work out, mine did. You are only sanding the clear coat, not the paint, so be gentle.
2. Put the rubbing compound on cloth towel and work in circular motion. Again, be light and careful here. You should be able to buff it out, but will still have little swirl marks.
3. Final step is to use the Mequires swirl and scratch remover on a towel. This will buff back to original shine.
Take your time. I managed to get out all but the deepest scratches (the ones that went down to the paint). Didn't cost me much, and looks much better than before. Hope this helps. D.
I really like the Meguires Scratch X stuff... It is the greatest on my black truck for door damage abrasions and all the claw marks from the dogs that jump up to greet me and the stupid cats from jumpin on my hood~
I pray every night that no one ever gets up the nerve to actually key a vehicle... ::CRINGE::
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
