Christmas Cash In
SnakeEyeSS
As some of you may know, I bought a load of Nintendo DS's(7, have 3 now, picking up 4 in a little while), since every9onewas reporting it would be one of the biggest items of this year.
Yesterday, several sold for $190 or more, today they are selling for $175 ish.....retail is 150.
right now there are 2700 listed on ebay. One million will hit American Markets b4 christmas.(there were three times as many PS2's when they came out)
is this a good or bad sign? I'm famliar with ebay, but never followed holiday gift trends until this year. I figure they might be going for well over 200 in a few weeks if some are willing to pay 190 right now. I figure I'll also save a few to possible put in teh classified in the local paper. stuff like that always sells out around Tulsa.
well since I posted that 3 minutes ago, like 20 auction have ended, more started. I just checked again, there are going over 200 in some auctions. I guess I have to hang out a while longer.
    Sothpaw27
    Sothpaw27
  • Who's Online   4 Members, 0 Anonymous, 825 Guests (See full list)
