Trans swap, need help please
I have a 1982 GMC 1/2 ton 4x4.
It has a 350 trans in it now, I also
have a 91 camaro 700r-4 trans I
want to put in it. I am told I need
a conversion kit to fit the 700r-44.
Where can I get one, or what do i
really need to do this swap. thanks
:thumbs::thumbs:
You need a different TH700-R4. The 2WD version uses a lighter case, and is garanteed to break the case if you change out the tail shaft housing and hang a T-case off of it.
Not what you wanted to hear, but it'll save you some :cheers: down the road.
You gotta find a TH700-R4 with a big "K" mark on the side of it to start this conversion.
What a trip, that must be why my 350 case is cracked :dupe:
I don't even plan on using it for off road, I figured it hold up.
    Brendan C
    Brendan C
  • Who's Online   5 Members, 0 Anonymous, 1,105 Guests (See full list)
