"drive it until the wheels fall off"
SnakeEyeSS
soccer? do yuppie kids play soccer? isn't it like fraiser? wouldn't they play, er, be in plays, recite shakespeare, and have juice tasting clubs?
Four drivers reported a fracture in the steering knuckle, which allows the wheels to turn. All said they lost control, including one driver whose H2 veered into oncoming traffic and ended up in a ditch on the other side of the road. In three of the cases, a wheel fell off.
See guys One out of every four H2 drivers DO take them off road :cheers:
See guys One out of every four H2 drivers DO take them off road :dupe:
Hmm, maybe she hit a curb trying to get a good close parking spot at Starbucks. :cheers:
My truck has been two-toned black and brown on many occasions....Right now it looks like it's pewter...And you could grow grass in my floormats right now.
:cheers: That would be cool.
Hey, up until a few days ago I did have something growing in the floorboards. Not quite sure what it was, though it looked a lot like wheat. Decided to clean at the point where it was 6", but forgot to take pics.
    Gkistler
    Gkistler
  • Who's Online   5 Members, 0 Anonymous, 791 Guests (See full list)
