03 ss
hi, I'm new to this sight,, anyone own the 03 ss would like some opinions on it, any bugs that i should know about, also looking for brake upgrades,, stock seems underpowered, thanks in advance,, leo one more thing,, is there a h.i.d. kit available for this truck..
    Brendan C
    Brendan C
  • Who's Online   5 Members, 0 Anonymous, 970 Guests (See full list)
