Deep Sotuh Engineering Exam
OnBelay
1. Calculate the smallest limb diameter on a persimmon tree
that will support a 10 pound possum.
2. Which of the following cars will rust out the quickest
when placed on blocks in your front yard? A. 66 Ford
Fairlane B. 69 Chevrolet Chevelle C. 64 Pontiac GTO
3. If your Daddy builds a still that operates at a capacity
of 20 gallons of shine per hour, how many car radiators are
necessary to condense the product?
4. A pulpwood cutter has a chain saw that operates at 2700
rpm. The density of the pine trees in a plot to be
harvested is 470 per acre. The plot is 2.3 acres in size.
The average tree diameter is 14 inches. How many Budwesier
Tallboys will it take to cut the trees?
5. If every old refrigerator in the state vented a charge
of R-12 simultaneously, what would be the decrease in the
ozone layer?
6. A front porch is constructed of 2X8 pine on 24 inch
centers with a Field rock foundation. The span is 8 feet
and the porch length is 16 feet. The porch floor is 1 inch
rough sawn pine. When the porch collapses, how many hound
dogs will be killed?
7. A man owns a house south of Beckley and 3.7 acres of
land in a holler with an average slope of 15%. The man has
five children. Can each of the children put a mobile home
on the man's land?
8. A 2-Ton coal truck is overloaded and proceeding 900
yards down a steep grade on a secondary road at 45 mph. The
brakes fail. Given the average taffic loading of the
secondary roads, what are the chances that it will strike a
vehicle that has a muffler?
9. A coal mine operates at NFPA Class One - Division Two
hazardous area. The mine employs 120 miners per shift. A
gas warning is issued at the beginning of the 3rd shift,
how many cartons of unfiltered Camels will be smoked during
the shift?
10. At a reduction in gene variability rate of 7.5% per
generation, how long will it take a town bypassed by the
interstate to breed a country western singer?
    B07
    B07
  • Who's Online   0 Members, 1 Anonymous, 839 Guests (See full list)
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
    • Looking for this part for my truck. They don't sell just that one piece and to get it you have to pay over $100 even used for the whole air tube. The piece the hose clamp snaps into that is held on by the screw and nut. If anyone has access to one please let me know.
