electrical fuses
:ughdance:
I have a 1994 1500 full size ext cab truck. I keep on blowing out the fuse for the dashboard lights. When that fuse goes, I have no tail lights,horn,and radio. It just started today. I have gone thought 4 fuses ( 20 Amp) so far. What is causing it?
Thanks
Randy
Is the dash fuse the same one that feeds the parking light circuit? If it is, check the trailer light harness if you have one. I have seen this alot on toyota trucks. Somewhere to start anyway. Good luck. :ughdance:
    Brendan C
    Brendan C
  • Who's Online   5 Members, 0 Anonymous, 970 Guests (See full list)
