I CURRENTLY RUN 285/60-18'S ON MY YUKON BUT I NEED A WINTER TIRE. WILL 285/75-16'S FIT A STOCK YUKON (NO OFF ROADING)? BY THE WAY MY YUKON CAN BE SEEN ON BTG'S WEBSITE. WWW.BTGMOTORING.COM IT'S IN THEIR GALLERY FOR THE "WIDE BODY" STEEL COWL INDUCTION HOOD I INSTALLED. :ughdance:
If it is the old square body style, they will work on the factory wheels. I ran 285/75R16s on factory 16x7 wheels for three years. If you use aftermarket wheels, the offset may cause rubbing in the front.
The four door Yukon/Tahoe old body style sat 2 inches lower than the two door, pickup and Suburban because of shorter body mounts, to give a lower step in height.
    Brendan C
    Brendan C
  • Who's Online   6 Members, 1 Anonymous, 1,138 Guests (See full list)
