Attn: People Using My Sigs!
SlamminL5s
I Got A New Account Here Are Your Sig Pics And Codes
if you dont already know you have to remove all the * from the code in order for it to work right
[*IMG*]http://img.photobucket.com/albums/v323/Hayoj/weirdchildboy.jpg[*/IMG*]
[*IMG*]http://img.photobucket.com/albums/v323/Hayoj/Addonhehe.jpg[*/IMG*]
[*IMG*]http://img.photobucket.com/albums/v323/Hayoj/2f4bb0a4.jpg[*/IMG*]
[*IMG*]http://img.photobucket.com/albums/v323/Hayoj/1f6562b2.jpg[*/IMG*]
[*IMG*]http://img.photobucket.com/albums/v323/Hayoj/Background.jpg[*/IMG*]
