REPLACING REAR SPEAKERS
I have a 95 Suburban and Im looking at replacing the factory speakers in the rear, not the rear passenger door speakers but the speakers by the "barn doors". The only problem is that they are 4x10s and I would like to step up to a bigger size speaker and mount the tweeters on the slope in front of the speakers. Does anyone know the biggest size that will fit?
Thanks
Nick
depends on how much modifying you're willing to do.  you should be able to fit a 5 1/4 in there without too much trouble.  and bigger if you're brave with a sawz-all
Yeah I think Im gonna get brave back there, I have to replace the rear headliner because of water damage, so the area will be open to "adjustments".
If I do do this Ill post back here and let everyone know how it all went.
Nick
Guys...
If he's talking about 4x10s, chances are they are located in the same place mine are. In the ceiling.
And trust me, 8 inchers aren't going to fit without a lot of fabrication.
And there isn't anything to be using a sawzall on...Unless you're talking about cutting a hole in the roof.
Back on topic...you might be able to fit a 5 1/4" midrange in there, or fab up some brackets and put some 4x6 plates.
Crutchfield offers adapter plates to convert to 6x9's. Don't know how they look though.
Yeah I was taking a look at the mounting area a little closer and also realized there wasnt as much room as I thouht to put a bigger speaker in. I just ordered the Kenwoods and will live with those for a while.
Nick
  • 1 month later...
Nick
How did the Kenwoods work out?
Nick
The Kenwoods turned out to work fine. Being up front in the drivers seat you really dont notice them but I sat in the back row and the improvement over the non-working rear speakers is huge.
Nick
    Fishboat
    Fishboat
  • Who's Online   2 Members, 0 Anonymous, 519 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
