front brakes
1998 chevy 2500 w/454 4x4 how hard is it to change the front brakes for someone who has never done brakes? I am selling my truck and don't want to put any mor money than I have to. ---your opion please----shop or driveway???
    Brendan C
    Brendan C
  • Who's Online   4 Members, 0 Anonymous, 986 Guests (See full list)
