Trailer Fuse
Go down to your dealer and tell him you didn't get one with your trailering package. My dealer gave me three "just in case". Suckers cost about $7.00 if you gotta buy one.
My 99 came with a fuse taped to the harness. My 03 did not. I just assumed it was already there. Where is is located? Under the hood or in the dash panel? What is the label name for the fuse (ex. trailer 12V, etc.). I looked for it before but never found it. I am sure it is missing though. My interior lights on my enclosed trailer do not work and they worked when my 99 was plugged into it.
The fuse goes in the engine compartment fuse block. I think its called Accessory A & Accessory B if I remember correctly. It says in your owners manual which two feed the trailer.
The fuse for my '03 came with the harness I bought from the dealer. It was a 40 amp fuse and it went into the Slot 1 space in the Underhood Fuse Block. The Slot 1 space in mine had a red plastic piece in it to keep dirt out I guess. I think all it does is supply the hot 12v lead in the 7 pin hitch connector for trailer interior lights etc.
Thanks guys, it blows my mind that it did not come taped to the harness like my 99 did. Probably just another 03 "cutback" (like underhood lights, etc.) to save a dime at GM.
I didn't get a fuse on my 03 either.
So far I've taken two trips to the dealer and they still can't figure out which one makes it work.
My 03 did not come with one either and the dealer wont give me one (cheap SOB, all I got extra with my trailering package was that 7pin round to 4 pin flat converter plug). No extra harness for connecting a trailer brake and no fuse. If I knew the Littlefuse or Bussman p/n I would "check" at work...
Just checked my fuse that came taped to the harness and it is a Littlefuse brand and the number on it is 495, it is a 32volt 40 amp fuse.
I think the fuse is mostly for the trailer brakes, 40amps seems high for just interior lights. Plus it comes with the trailer brake control harness. I may be wrong but that is what I understood it to be for.
Thanks that is what I needed. Now to see if they stock them at work...
    Brendan C
    Brendan C
  • Who's Online   1 Member, 0 Anonymous, 913 Guests (See full list)
