NASCAR allows only HANS device in 2005
antig24
NASCAR allows only HANS device in 2005, bans Hutchens
By JENNA FRYER
CHARLOTTE, N.C. (AP) - NASCAR will only allow its competitors to use the HANS device in 2005 because the other head-and-neck restraint system did not meet performance standards.
Drivers have had a choice of restraint systems since 2001, when NASCAR began requiring all competitors to use either the HANS or Hutchens devices following an investigation of Dale Earnhardt's death.
NASCAR spokesman Mike Zizzo said Monday that the Hutchens failed to meet minimum standards from testing by SFI Foundation Inc. The HANS device was approved by SFI, a California-based nonprofit organization that sets standards for specialty/performance automotive and racing equipment.
The HANS (Head and Neck Support) resembles a collar and slides on like a football players' shoulder pads, then hooks onto the helmet. The Hutchens device is a series of straps that connect across the chest and at the waist.
Most drivers preferred the HANS, but Ryan Newman and Tony Stewart have been known to race with the Hutchens.
NASCAR mandated use of a restraint system in October 2001, after an investigation of Earnhardt's death the previous February. Earnhardt died of a skull fracture, the same injury that killed NASCAR drivers Adam Petty, Kenny Irwin and Blaise Alexander in a one-year span.
Many experts believed the fractures could have been prevented with use of a restraint system. But with drivers reluctant to use restraint systems and lingering questions about their effectiveness, NASCAR did not require their use until Earnhardt's death made the issue a top priority.
After numerous studies, the sanctioning body required the use of a restraint and allowed drivers to choose.
Last season, NASCAR evaluated several different systems, hoping to approve new ones before the 2005 season.
01/03/05 19:10
© Copyright The Associated Press. All rights reserved.
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
