xbox live
facn8me
Anybody else got it. Lookin to play. Have met some intesting people so far. would like to play against somebody a little more mature. I have a bell handy :D school is in session. :fume::cheers:
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
