4X4 causing problems
Ok i have a 99 sierra Z71 with a 5.3.. up until tonight the service 4x4 light would come up in the dash and i had the switches adjusted but that didnt seem to work so i went out to my field today to check on some stuff and started to get bogged down in the mud i tried the 4x4 and it engage perfectly so i get through fine go to switch it back to 2h and it wont go it stays in 4h! after restarting the truck it still doesnt go back but then the selector dash goes blank and service 4x4 comes up on the information center!! is this a switch problem or is there something wrong with transfer case also it doesnt seem that i have limited slip in the rear but im not sure anyone know??
    Brendan C
    Brendan C
  • Who's Online   5 Members, 0 Anonymous, 1,020 Guests (See full list)
