Cold Weather auto tranny shifting
I have noticed lately when the air temps drop 8-10 degrees below freezing that my 99 Silverado Z71 seems to take longer to upshift in the first few miles of running.
This morning the outside temps were about 25 and in the first couple miles of driving at 25 to 35 on residential streets, the tranny didn't want to shift into 3rd below about 35 and it wouldn't shift into OD until I hit almost 40. I could force a shift into OD by going faster but as soon as speed dropped below about 36, the tranny would drop back to 3rd. Moving the shift lever between 3rd and OD made no difference.
Water temps at this point were from initial start-up to about 150-170 degrees. The 1-2 upshift seems normal and is firm.
The truck has just under 50K on it and the tranny otherwises shifts fine and all the shifts are firm. I don't tow anything or shift manually. It almost feels like the tow/hual mode is activated.
Any ideas/comments??
The transmisson has a temp sensor in it that does stop the convertor from locking up until the transmission reaches a certain temp. It may also affect the shifting. Plus it will shift different when the fluid is cold.
Mine too...seems to shift a little harder from 1-2 when warming up (live in Mass), also depends on what speed the truck is going (how far my foot pushes down) it will shift real smooth or a little firmer, when putting around seems to shift harder than when taking off normally. Seems a little touchy and really depends on how I drive but I guess the cold weather and the fact the transmission is always 'learning' will lead to this, but acted this way since new....hope this helps. :D
when its cold mine holds the gear longer and the engine sounds different....kinda like air rushin thru it
but its normal
04 z71
So, they are supposed to hold shifts longer when cold...and the character of the shift changes too? As I said, mine seems to shift a little harder when cold (just 1-2 though). Dealers say normal..... :D what do you guys say, sounds normal and I guess some people prefer harder firmer shifts anyway? Thanks :confused:
Yep, that's normal. Even on non electronically controlled transmissions, the shift characteristics will be different when cold due to the physical properties of the trans fluid at different temperatures. Combine that with the PCM logic, and you will feel a difference until the vehicle warms up.
c4crusier..did not mean to push you out but I posted a similar question....but as I said earlier, I think this is normal... :confused: I have an 04 with a shift issue when cold also and wanted to explain what I notice...this is a great forum for these types of questions :D
One big reason they shift that way when cold is to speed warmup time. May even be CAFE related as faster warmup leads to less pollution and better mpg.
if I let my silverado warm up for about 3-5 min before driving it I never have any problems with it shifting however if I do a cold start and drive immediatly it will shift like you describe. Try letting it warm up for 2-3 min (until the idle drops down to normal) and then drive. Saves wear and tear on your engine and tranny.
Yes, I'm convinced it's all about the fluid and the e-controlled drivetrain. We have had the standard farmin%$k&^g winter freezing arse cold here (-40c = - 40f... right?) . I have been plugging in and burning alot of fuel warming up before driving (15 min +). I understand that recommended practice is to set the "PARK" brake and put the trans in neutral in order to warm it during exteme conditions. I dont trust my 'emergency' (formerly known as) brake though. Truck goes 20 miles+ to work at these low (outside) conditions and crappy roads with normal engine temp, but the transmission shifts like it's in tow/haul mode the whole way. I don't think it warms up. I kind of wish i had a shut/cutoff valve for the tranny cooler; just for these conditions.
Was reading an AC Delco tech newsletter at out shop yesteday and there was an article reagarding this problem. The article said that the shift solenoids may be the problem and delayed shifting due to cold temps can happen in any upshift pattern (1-2, 2-3, or 3-4 or all of them). But the issue was tranny specific.
And of course, I can't remember the specific tranny model mentioned in the article right now (another case of CRS :thumbs: ). What tranny is in the truck I have?? 5.3L motor, Z71 1/2 ton ex-cab. A variant of the 4L60E??
    250.3k
    BDS my HD
    BDS my HD
  • Who's Online   0 Members, 0 Anonymous, 649 Guests (See full list)
    • Hello hello looking forward to expanding my knowledge of the 2026 2500 HD that I just bought.   Truck has 3500 miles on it four-wheel-drive crew cab and I’m about to put a 6 1/2 inch BDS lift on it 18 x 10 -25 offset with 37’s   Already have the wheels and tires just waiting on the lift install in about three weeks   Question what surprises am I not gonna be happy with?  I’m not new to lifted trucks so I know that acceleration towing gas mileage all that is affected..   Question is those of you that have this truck this powertrain with a 10 speed Allison and have done the mods that I’m doing,,, how bad is it? Is that Allison constantly gonna be hunting for the right gear to go into? And what about towing, acceleration, fuel consumption as mentioned?    Lastly how come I can’t find any ring pinion gear set up for these axles and when could I expect to see them?   I apologize if there’s any typos I’m doing speech to text on my iPhone.
    • I've got a 2013 2500 6.0L Flexfuel. Drove the truck earlier today with no issues. Went to run an errand tonight and noticed key fob wouldn't work. Figured battery was dead, so replaced fob batter. Still wasn't working. Grabbed my other set of keys with the other fob and that one wasn't working either. So I manually unlock truck and insert key. Interior lights come on, dashboard lights up, turn key and truck starts. Turn truck off, like a moron, and try starting again. This time no crank, no click, no nothing. Lights still come on and dash lights up, but now I'm getting a service 4wheel drive, service tire monitor, etc. Check voltage on battery and Im showing 12.2v. Throw my battery charger on it and give it 15 mins and try starting again. But still no crank no start. Decide maybe its a bad battery, run to autozone grab a new one and put it in. Same issue. Disconnect battery and let it sit for 15 mins. Try again and still nothing. I had managed to roll the windows down earlier as its a humid night, but now I can't get them to roll up. Power locks are also not working now. Then randomly I try the key again, and it fires right up. Immediately I roll up the windows as we have nothing but rain forecast this week. I shut it back off wait 30 seconds and start up again. Worked a 2nd time. So turn it off, start putting things back together. Try one more time, and back to no crank no start. And now the car alarm starts going off. Had to disconnect battery and leave it that way for the night as I don't think my neighbors would appreciate my alarm going off again tonight. Any thoughts or help would be appreciated.
    • No one will care for you like you care for you. Do what you can for as long as you can. IMHO of course.
    • How about them NICKS!!!
    • Hi there.  Long time lurker, first post.    i have read the previous posts regarding the water ingress problem with this emblem.  I bought my 1500 SLT the  summer of 2025 new and after reading the MANY problems with these emblems failing I decided to install one anyways.  As per a YouTube video, I sealed ( or tried to) this sign with silicone sealant around the outer perimeter joint and the holes that were already somewhat sealed on the rear plate of the emblem.  And installed the connector assembly using dielectric grease on the connectors. The installation looked great and worked well for about 4 months……then FAILURE.  Grrrrrr…… I live in the great white north and wash my truck weekly in an automatic car wash  to keep the salt off.  Let me tell you that removing the old, failed emblem is a whole different animal than removing the OEM individual letters without removing the grill assembly. Mainly because the illuminated logo is built differently than the original letters which  you can remove the red surface lettering with a knife or some kind of blade which gives access to the tabs which hold the logo onto the grill. So I had to essentially destroyed the old emblem to remove it. Doing so killed my chance of doing somekind of autopsy on the failed , old logo.  But there was plenty of water inside when I ripped it apart.  Prior to installing the new assembly I tried it with the old harness and it works fine.   Does anyone have any insight as to where the water is getting into this emblem? I intend to seal the new logo with slow curing epoxy this time around using a syringe.  I think this newer emblem may be an updated unit which I hope GM got the vendor to fix. It has an October 2025 date on it.    If this one  fails,  I am just going to revert back to the non-illuminated letters….AFTER PULLING THE GRILL.    Any thoughts on sealing with epoxy would be appreciated. Thx!   Doug
