Bump Stop in the Front
I got a 2001 Chevy 1500 RCSB 4x4 and I was lookin under my truck today and noticed the front bump stop was significantly close to the lower arm. In the attachted pics you can see what I speak of, but I was wondering is that rite? is it ok? and does a 4x4 supposed to have a raked stance or was it caused by someone lowering the torsion keys.
Wow, that does look close. Has it always been this way? Mine's a 4x2 with coil springs so I have a different setup. My lower control arm is pretty close but I'd say there's a good 2-3 inches. Are they both like that? If you bought the truck used or if you've had it in for suspension service it may have been 'played with'. But, I'm no expert, that's just the way it looks to me.
Yes, That is the way it is supposed to be. The bump stop on NBS trucks also acts as a progressive dampner for the torsion bars. In other words it makes the ride on your truck smoother. The further the Bump Stop is away from the LCA the harsher your ride will be.
:D
Most of these trucks have a pretty raked stance also...not too many people adjust the torsion bars to lower the front, they usually go the other direction to try and bring the nose up.
GM engineers designed the front compression travel stops to engage as soon as the suspension begins to load. The stops actually supplement torsion bar (spring) rate. If the torsion bars are adjusted-up for increased lift height; more height creates more air space beneath the stops. Too much spacing creates a "spongy" ride, increased body roll and sway, excessive nose-dive when braking, and torsion bar fatigue.
That being said I have mine cranked up for level ride height. Ride is same or better IMO
ya, mine looks close too. but i think people with 2WD should not be offering up. maybe if my front driveline is giving me some problems i can look for assistance in the 2wd forum? not. jeez. and me without my wallet.
I LIKE to see how the two trucks compare...
    appletrav
    appletrav
  • Who's Online   5 Members, 0 Anonymous, 307 Guests (See full list)
