temperature sensor question
I replaced my factory temp sensor last march (with one from the dealer) because it wasnt sending to the dash gauge. In december the replacement one poped out/broke(the plasctic piece came out of the bronze treaded fitting that screws into the block). So got another on from the place i get my truck inspected(figured i got a bad one from the dealer). Just today the dash gauge stoped working.......it happened again the temp sensor came apart....anyone have an idea why this is happening??? :cheers: ..... 92 GMC 350 tbi
2001bigblockburban
Sounds like you're cranking the new ones down too tight and distorting them.
Wrap about 3 turns (no more than) of white teflon thread tape and install it with a box end wrench no longer than 6" and don't tighten it very tight. If it leaks, snug it down a little more, but not much at a time (1/6 turn each time).
Get AC/Delco or Genuine GM parts if you want the best. Otherwise, take your chances...
THANKS 71 GMC, I THINK THAT WAS MY PROBLEM ....CRANKED IT ON THERE TOO TIGHT .....I'II PICK A GENUINE GM ONE TODAY......AND SEE HOW THAT WORKS.....I'LL LET U KNOW IF IT HAPPENS AGAIN......THANKS FOR THE ADVISE
