Radix Pulley Question
Folks:
Has anyone tried the 3.2" 6.0 L Pulley on 5.3L Magnusson Radix which has a 3.4" pulley. The 6.0 L pulley would spin tne Radix about 6.25% higher.
Regards,
Durkin
smaller pulley will give you more boost, you can order smaller pulleys, i think they go as small as 2.90, would recommend getting a retune to avoid any proplems and get maximum performance from it, you might have to use a smaller serp belt
You have the stock pulley on a Radix and are running the Snow injection system? Water/meth injecton shouldn't be needed at all with the stock 6psi pulley. You should really be able to drop pulley size without detonation. A 3.2" pulley should be just fine and work on the same belt.
I'm running a 3" pulley on my 6L but have a 2.70" pulley for the track.
  • 3 weeks later...
Durkin, there are a lot of guys on LS1tech.com that run the radix with smaller pulleys. I'm sure you can find some good information there.
Jeff
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
    • Thanks; I looked there a few minutes, and I think I can find something. I really never looked there, as I thought it was stuff like PTO/aftermarket bodies/accessories like snow plows.
