Horn issues
Pulled all the crap apart to get to the horn, tested the horn on another truck, and it works just fine, put it back in the truck Im working on, and nothing. Checked fuses, checked relays, all seems good. What could be the deal?
The problem could be in the steering wheel switch, when you press the horn.
Personally I would get rid of the crap horns that they put in these Trucks. These horns sound like they belong in a Toyota.
I replaced my horns with AIR HORNS! The Horns are behind the Bumper.
I agree with the sound of the horns! I'm almost embarrassed to use it on anyone I know for fear they'll laugh at me...
Back to the inop horn(s). Does the relay click when you have someone press and release the horn button a few times? If it does, the problem isn't in the horn button. If it doesn't click, look around for fuses blown first, inside and out in the engine compartment, then go after the horn button. BEWARE of the Air Bag!! There's a special procedure on how to disable them BEFORE you do anything else. It would f- up your whole afternoon if you had one go off while you were working on it!
Where did you get your air horn kit? I have been wanting to do this.
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
    • Melling I believe is/was the OEM on the lifters who explored this problem some years ago. The white paper they generated on the topic indicated two items of note when I read it. 1.) They only fail on the switch. Prevent the switch, prevent the failure. 2.) The majority fail due to deposits messing up the timing of that switch. Anyway that's what I got from it.    Mine have always been active, 195K+ now, and my oil maintenance is surgically clean.    Of course this assumes good parts. That is no heat treat issue or machining flaws. I get comfortable that these issues are in the rearview mirror by about 30K. IMHO naturally.
