Sure is nice to have two trucks
Jpshostr
After years of only having one truck here on the farm, its sure been nice to have two around.
I couldn't help myself, had to start using the ol Cummins for chores once she hit 700 miles, got almost 1900 on it now after a month of ownership. Sure handles the pasture and fields a lot better then the Chevy does, attribute that to the bigger tires, solid front axle, and a tighter limited slip in the rear axle. Chevy also feels like a car now, so low to the ground. :wtf:
Still don't have my gooseneck or my DMI hitches put in yet, but running boards are going on Monday. I am really itching to get a trailer or implement hitched on.
You should get something for that place where the front plate goes... I personally can't stand it when those things are blank. :thumbs:
....Or better yet, take the holder off. :D
Well, remember, I've had the truck one month now......plates aren't here yet.
Oh, I see. Are you running temps?
When we bought the X-Terra they handed us the permanent plates at the dealer right after we signed the papers.
I would figure the Cummins would be heavier on the front end... not exactly the best choice for runnin around in the mud IMO.
What Axle does dodge use? AAM? I never liked the dodge limited slip... I'd go with a locker, not exactly the G80...
Hope trailering goes good with the cummins. Get a good cushion hitch for pulling wagons. You seem to be set on DMI, I'm pretty happy with shuck hitches.
    jaszr2
    jaszr2
  • Who's Online   5 Members, 0 Anonymous, 460 Guests (See full list)
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
