How much is this worth
SnakeEyeSS
Camaro/small block anniversary Poster
long story short:
3 years ago a GM master mechanic gave that to me(personal friend). it had been given to him as a thank you from a GM excuitive or engineer or something when he was in Detroit one time. yesterday I finally framed it, in a nice brushed aluminum frame. well it fell off the wall, busted the $20 frame, broke the plastic cove,r and creased the particle board backing, which in turn slightly creased the poster(once framed it will probably go away). poster is in great shape, and the mechanic said he had only seen one other like it at an Oklahoma City produiction facility.
should I keep on on ebay or keep it myself?
I got one hangin at work. cool poster. The rare one(supposedly) is the first annual brickyard 400 poster. It has earnhardt holdin the trophy but gordon won. Got one of those too. I got mine fron GM school in 94-95
oh it was a promotional item sent to most dealerships for display purposes. the school had the leftovers. Supposedly the brickyard ones were to be destroyed. Don't know if it's true or not but at least 11 others got one.
I think the cool factor of having it is better especially with the muscle ya got now. A little history to go with your ride. keep it unless the bid goes real high then I'm puttin mine up :thumbs::smash:
I vote for keeping it also,I got one myself (also got it at GM school) along with the first three Brickyard 400 posters ('94-'95-'96) that facn8me metioned.
I always thought GM had some pretty cool posters in the '80's and '90's and you don't see many nice ones (if any) from them anymore for whatever reason.
