Talk about a crappy day
tmf6902
You would think the airlines....any airline..... would be at her place in an instant to do whatever they could to keep this under wraps.....the last thing they need is for the public to think they're being crapped on (pun intended). :thumbs:
She should demand DNA testing. It's probably a terrorist attack.
WHAT.....you can't do that......you know you can't do that.....why.......why....thats PROFILING :withstupid:
    zibzer2
    zibzer2
  • Who's Online   5 Members, 1 Anonymous, 784 Guests (See full list)
