Center Console Key
I bought my truck used several years back and have never had a center console key, where would I get a replacement?
1999 GMC Sierra 1500 new body style, ext. cab
When I bought my 02 used, I tried a local locksmith and they were totally useless. I showed up to the local dealer they read the vin and were able to order a set of keys which arrived in a matter of days. Much easier than replacing the whole console as the locksmith suggested would be neccessary.
Go to the dealer...they order them from a company called Hurd. They make the cylinders and the keys for GM. All the cylinders are coded with a number that you can see on the lock, where you insert the key it is usually 3 digits. There is a TSB on this subject, so the dealer should know what to do...but they will need the code off the lock. Hurd unfortunately will not deal directly with the consumer, and it costs about $35 for 2 keys. I need one as well...but thats a little steep!!
Thanks Black-Z71, this was the info I was looking for, that is TOO steep, do you know if you can just replace the barrel with a new one or where to order a new barrel?
You can order a new cylinder with 2 coded keys thru your dealer from the same company, and it'll cost you a little less. But, the cylinders are sonically welded to the plastic, so there is no easy/cheap way to replace the entire cylinder. I don't think it is held in with a bolt, I just haven't tried it myself. I'd like a key for my console, but I just can't justify paying that much for it...
Might want to take a look at this thread from some time back. I was in the same predicament with an 01 I bought used. A dealer can get you the keys from Hurd Corp. Theres a TSB from Alldata: 01-08-49-017 OCT 01 Center Front Floor Console Lock & Key - Availability If you can give this to a dealer you can get the key for your truck. These's a code on the lock cylander they will need. Good luck.
vroten :chevy:
Isn't that what I just said... :chevy:
I just give Hurd's 800 number to the customer and they can call and order as many as they want. I can get that number when I go into work tomorrow if you want it. You might be able to Google it.
Sorry, but you have to realize that most of the dealers in my area are as confused as a termite in a yo-yo. I thought if he had the TSB # it might help, because as I went through this a year or so ago no dealer had any info on it. Its nice, thanks to this board, when you know more about these trucks than the "experts" down at the dealership.
vroten :D
vroten
I hear that...I know the feeling of seeing a blank stare from a so-called "expert" you are asking a question. :chevy:
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 788 Guests (See full list)
