new to forum, desperate question
1st post on forum.
i've had my 99 silverado since it was brand new.  since that time, i've talked to multiple dealerships in 3 different time zone, plus the chevy and GM internet "no-help" site.  No-one can provide any helpful information.  i'm getting desperate.
The 99's will not allow the user to disable the "Twilight Sentinel" feature which turns the headlights on at an arbitrary darkness level.  i'm not talking about the DRL's, just step on the e-brake and they go off.  I need to turn off the actual honest to goodness headlights.
I'm active duty Air Force and every morning, coming through the gate, i blind the poor kid guarding the base.  besides being down-right mean to them, it's also not the wisest thing in the world to tick off an 18 year old "baby-airman" with a gun.
can anyone tell me how to turn the stupid things off????? i've tried pulling every fuse and relay under the hood to no avail...
help!!!!!!
First of all welcome to the forum. Second to my knowledge you are out of luck. The 2000 and up have an override feature but not the 99s. Sorry I cannot be any more help.
The dealerships have all told me that it's illegal for them to disable the "safety features."  Safety features, my left foot.
They've also said that someone who knew their way around electronics might be able to do it.  the sensor is located right on the front of the dash -- just about directly under the rear-view mirror.  My ball cap always slides onto it and turns the lights on.
From the Hayne's schematic (don't waste your money, haynes is trash) you cannot tell if the sensor opens or closes the circuit.  if it opens the circuit, i could theoretically just cut the wire going up to it and solve the problem.
if it closes the circuit, that puts things way beyond my expertise -- i ain't gonna try to rig a power source or anything like that under my dash; i'll end up with a pile of ashes instead of a truck.
i'm not willing to take that much risk with a year's wages worth of truck.
Oh well...
Hi there. Welcome to the forum!
From what i've heard, at dark the photodiode acts like a resistor would. I'm pretty sure that, and i've heard this before, if you take the right value resistor and insert it in place of the diode, you can get full control over your lights. I'm not sure of the exact resistor value.
thanks for the quick replies!!!  great forum!
on the 99's the over-ride hadn't been included.  they got so many complaints (many from me personally) that they put the override!
i really appreciate all the help.
maybe i'll tinker around with a voltmeter/ ohm-meter this weekend to figure out the resistance.
Welcome to the site brax71, I'm in the Air Force too.
I also have a '99 and here's what I've found about the lights.  R & D make a switch that goes next to your air bag cut of switch that will do the trick.  You can switch between the factory automatic head lights, or manually operating them like the "old days".  LOL.  Unfortunately it's ?.00 plus S&H.  Since Christmas I've been saying I'm going to order one, but still havn't.  One of these days I will though.
There is also a free was of disabling it permanantly.  You could undo it all and put it back to stock I guess, so I guess it's not so permantent.  Here's a couple different links with instructions.
http://forums.vmag.com/ptsilverado/messages/149.html
http://drive.to/silverado4x4  If this one doesn't go directly to the instructions, they are under the modifications page.
Hope this helps.
there is a kit that can do this for you...  I saw it mentioned on PUTC 6-8 months ago...  I'll try to get you more info
woo-hoo!!!!  2 years of griping solved within 18 hours!!!!
Thanks, gents!!!!
we've just found the "project" for the weekend.
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
