REAR MUD GUARDS
MTRMAN5
I INSTALLED GM REAR MUD GUARDS ON MY 04 YUKON XL WITH THE SUPPLIED PARTS IN THE HOLES IN THE FENDER FLAIRS WITH THE SUPPLIED PLASTIC PUSH PINS. I NOTICED THAT THE MOVEMENT OF THE GUARDS IS TAKING OFF THE PAINT, SO DON'T BUY GM ACCESSORY (MUD GUARDS) . I CONTACTED GM AND THEY MADE A APPOINTMENT AT THE LOCAL DEALER AND THEY TOLD ME IN SO MANY WORDS (TOUGH S#@$). I COULD UNDERSTAND IF IN PURCHASED AFTER MARKET BUT THESE CAME FROM A GM DEALER. I SHOULD HAVE PUT THEM ON WITH TWO FACED 3M TAPE, BUT THE DAMAGE IS ALREADY DONE, NOW THE REAR FENDERS HAVE TO BE PAINTED. BEWARE OF GM PARTS. :)
  • 1 month later...
I have GM mud guards on my Silverado both front and rear. No problem here.
I know what he means. There are two kinds. The simple flat kind should be fine,
but the one I bought wraps around the fender for a portion at the bottom, and that did rub the paint off. It took a couple of months before I saw the problem, but I can see that it would happen to others as well.
  • 4 weeks later...
I had the wrap around kind installed on my truck when it was new. After the paint came off, my dealer did repaint mine for me. I was the first problem he had seen like this. He put clear plastic 3M tape on the lower fender and re-installed them. In a couple months, it wore thru the tape and the paint again. He did re-paint them again for me, but I was not about to put them back on the truck. I now have flat ones and they work/look great.
  • 1 month later...
MY WIFE DRIVES THE 04 YUKON XL DAILY, APOX 35 MI. TO WORK, I HAVE NOT LOOKED AT THE REAR GUARDS FOR A WHILE, BUT THE DEALER THAT I TOOK TO IN NAPLES FL, SAID NOT A GM PROBLEM ALTHOUGH I PURCHASHED THEM FROM A GM DEALER. OH WELL GUESS I WILL HAVE TO LOOK AT IT SOON LIKE THIS WEEK END AND TAKE TO A BODY SHOP AND HAVE IT PAINTED. MAYBE I COULD SEND THE BILL TO GM. HA HA. YES MINE ARE THE WRAP AROUND TYPE, IF THE BARE METAL IS NOT SHOWING I WILL TRY 3M DOUBLE FOAM TAPE. I HAVE ANOTHER PROBLEM AND I HAVE NOTICED LATELY THAT GOING OVER SPEED BUMPS I HERE A BUMP NOISE COMMING FROM THE RIGHT FRONT SEEMS LIKE AROUND THE FLOOR BOARDS. I WILL LOOK AT OTHER BOARDS AND POST THIS BUT I THOUGHT I WOULD THROW THIS OUT HERE AND SEE WHAT HAPPENS. I HAVE BEEN UNDER THE TK. BUT NOTHING SEEMS OUT OF PLACE, AND THE RUNNING BOARDS SEEM TO BE ATTACHED OK. THANKS MTRMAN5
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
