New Guy in New England
ProSport Tim
Well guys I just wanted to say Hey. I just became the proud owner of an 05' Sierra 1500 w/ the Pro sport package. I love the truck to death already. Very smooth and plenty of power. It's got the 5.3, automatic, and every bell and whistle I could get. Got a great deal on her too at $31,000. Wish me luck!
Tim
