Early Allison O/D Lockout switch
Thanks bluenote.
I had An 01' with a 8.1 and installed one on mine. I found a service bulliten put out from GM that said the switch was avail from the dealer. After a few trips to the dealer I finally found a service advisor that didn't mind doing some leg work and he came up with the switch from GM. It mounts in the open spot in the dash under the passenger air bag lock out . I installed it my self it came with instructions. Just a simple wiring harness to plug into the fuse panel. Then you have to take it to the dealer and have the computer programed to except it, they charged me an hour labor. Good luck. Deffinatly worth it if you tow alot.
    • Did you ever get this worked out? Mike is doing the two start thing now too. This is after a new camera back in December.
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because it’s in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
