Billet Grilles
What is everyone's experience with Carriage Works billet grilles?
I want to get one for my truck, but want to know if there are any
horror stories with them or anything. Also, which would be better,
the bolt on or cut out one? I would think with the bolt on kind, the
factory grille would still show through. Is the cut out one hard to install?
Here are a couple pics of them. The first is the bolt on, second the cut out.
http://www.carriageworksinc.com/products/41852.html
http://www.carriageworksinc.com/products/41862.html
Oh yeah, has anyone dealt with truckxpressions.com before? How are they?
Ive got one.  Its been in for 2 years.  Still looks good and I dont clean it or polish it much.
Cool! I just ordered one from JPCustoms :seeya:
It's the cut out kind though, Carriage Works doesn't make a bolt on
one for the 05's yet. Time to find the hacksaw blade. :chevy:
