Power Steering Fluid
I have 42K on the truck and was thinking of flushing the fluid, dealer quoted about $95.00. Seems steep. Can this be done w/o special equipment? What about the turkey baster method, taking some out, replacing and doing it on a monthly basis until it is all new?
i used the turkey baster method on mine. it is kind of sloppy though and i thought i read a better way to do it on here after i had done it.
it did seem to make a differnce though - the steering felt "different" after i did it.
the old fluid was black as could be - i was very surprised to see the new stuff was clear!
Don't spend a penny for that. Here's how to do it:
-Remove the fluid return hose at the power steering pump inlet connector.
-Plug the inlet connector port on the pump.
-Place a large container under the fluid return hose in order to catch the draining fluid.
-Run the engine at idle while an assistant fills the reservoir with new power steering fluid.
-Turn the wheel back and forth, fully to the left and fully to the right. Do not hold the wheel at a stop or a sudden overflow of the reservoir may occur.
-Install all of the pipes and the hoses.
-Fill the system with new power steering fluid.
Did mine last summer, works great!
Stef :crackup:
Stef :crackup:
Sounds good. What did you plug the inlet with? How much fluid did it take fo the flush/fill, want to be sure I get enough but don't want a lot of extra sitting around. Thanks!
I pluged it with a piece of rubber hose (automobile type), if I remember correctly,
I think it was 5/16 or 3/8, not sure but you'll see when you'll take it out.
At the other end, just screw in a bolt of the same diameter. Don't worry about the pressure, the fluid will just circulate and exit at the open end.
I think it took me a quart or two. The fluid is not expensive, keep some for later adjustments.
Stef :crackup:
Thats the same way that I did it, when I converted my brakes from vacuum assist to hydroboost. Works well. Just be sure to have plenty of fluid.
