horsepower help
:D i have a 97 chevy 1500 with a 5.7 and i need a few mor hp. i have cold air induction, mass air flow sensor, throttle body, programer, corvette servo for the tranny, gear and exhaust, and i just wanna get a little more out of it without going broke. and i know horsepower aint cheap. i was thinking about sliding a camshaft in it, or put some 1.6 rockers on it. or just rebuild the motor and put some more piston in it, but i dont know what will work with my computer. any advice would be greatly apreciated. thanks mike
Have you checked into a Wester's custom tune? You
said you had a programer, if it is a hand held, Wester's can do a lot
better.
Just my opinion!
Bud
right now all i have is a hypertech programmer. how much is a wester's, where can i get one and what is the gain on it? i thought about getting a venom programmer, but i wanna hear someone elses opinion before i experiment.
well its cheap to rebuild when you work at a parts house smart ass! and i have tried underdrive pulleys, but if you set through a drive thru your s**t will die, i got tired of jumping it off haha
    Brendan C
    Brendan C
  • Who's Online   5 Members, 1 Anonymous, 1,163 Guests (See full list)
