Squeak in dash area...Make's me crazy!
JRKRACE
I have a problem with squeaks. I know trucks will squeak, but this will drive anyone nuts. :fume: Here's the deal. In an area near the dash on the drivers side, there is a squeak that happens when I go over some MILDLY bumpy roads and when I take off from a stop.
It seems that when the suspension unloads, I get this squeak. I can also get it to happen when I lightly torque up the truck in drive.The squeak is much more apparent in the inside of the truck as opposed to the outside. I have tried listening to it with the door open and it is definitely louder when the door is closed. The sound is also definitelty heard in the FRONT of the truck.
I have taken the dash apart, lubed all the contact points between the hood and rubber snubbers, taken the front shocks off for a short ride and have had the dealer check it out twice to no avail. I have also lubed all 11 zerks myself and still come up stumped. :happysad: Any help would be appreciated....Thanks
Sorry...The vehicle in my sig...the 2004 GMC HD 2500 4X4 6.0 auto CC/SB SLT.
Yeah, saw that, but you have two so I wasn't sure which. :happysad:
LOTS of shocks off center at the top mount causing a noise just like you describe, but you said you took both off and still had the noise. So I guess that's not it.
You don't have anything like aftermarket running boards, do you? If you pull the hood release and leave the hood on the safety catch and drive it, do you still have the noise?
Noises can be VERY difficult to find, even when the vehicle is sitting there right in front of us. Trying to figure one out over the Internet is not easy.
Truck is totally stock except for plow. Drove with the hood on the safety catch and still does it. I plowed snow two days ago and the squeak is even worse with the plow up. It's gotta be suspension related, but the noise is so clear INSIDE the truck. Makes me want to rip apart the interior.... :happysad:
Some noises can travel and really fool you as to their actual source location. Can't tell you how many I've heard one that you'd swear was right in the dash and ended up being out in the front end somewhere.
:wtf::nopity::D I finally figured the d**n thing out. I noticed that it seemed to do the same noise when the truck was rocking back and forth on the park position. I climbed under the truck and started to move the truck back and forth. I could hear the noise and see the engine/trans flexing. Sure enough, there is a clip that holds the tranny cooler lines located between the tranny and t-case. The d**n clip was rubbing on the body. I moved it up a couple of inches and VOILA!!! ALL GONE! The auto lords were great to me tonight....
  • 2 years later...
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
