Bilsteins on a Z71
Does anybody know if Bilstein will honor any warranty on the Bilsteins that came stock with my 96 Z71? I thought Bilsteins are lifetime warranty? Am I wrong? Or just dreaming? :happysad: I appreciate your response. Thanks.
I certainly am not sure, but I am betting that they arent. Many OE parts made by manufacturers such as bilstein are not exaxtly the same quality as what they sell to the aftermarket. I think tires are a good example of this. How many times have you ever had OE tires prorated when they are bald at 20k?
Matt
When an OEM part, the vehicle warranty is the only thing that matters. Bilstein may pass along the warranty to GM but will not to the end user. I strongly doubt they will replace them.
Now even with new purchased shocks, the warranty isn't all that great. I believe the warranty only covers leaking shocks. I replaced my Bilstein HD's after 70K because they were not working well anymore. They were not leaking but were not damping as well as when new. I called Bilstein and they essentially confirmed that they would not warranty a non-leaking shock but they also said they expect 50-100K lifespan of a new shock before it's damping properties change even if it is not leaking.
Standard test for me is to bounce one corner at a time and see if it takes more than 2 cycles to stop completely they are toast.
I find that any high-pressure mono-tube shock lasts about 6 or 7 years. Then it's time to replace them.
Even if the OEM shock is identical to an aftermarket replacement, the warranty will differ. Typically shocks are only covered under your base warranty. The replacements you purchase may have a limited lifetime warranty.
    appletrav
    appletrav
  • Who's Online   4 Members, 0 Anonymous, 281 Guests (See full list)
