Silverado Interior Lights
ok guys...a little background.
I gotta 1994 Silverado single cab. The pins on the driver side door are worn and the door is sagging a little. It does take more effort to close the door.
Tonight when I got done runnin' I closed the door and noticed that all the interior lights are still on. I would pull the door open a little bit and the lights would shut off. I'd close the door all the way again and lights would come back on.
On 94's the dome lights are triggered by a little switch in the side of the dash. The switch is pushed in when the door closed. I closed the door and shined a flash light to see if the switch was maybe slipping (because of the sagging door) and its pushed in just as much as the other door (still in good shape).
I'm thinkin' that maybe one of the wires inside the door is kinked or something and is casuing the lights to come on? Is there ANYTHING inside the door that can control this?? A while back I noticed the door panal was loose so I poped it back into place, and broke one of those cheap a*s plastic pins in the process.
Any help would be much appriciated...I dunno jack squat about electronics.
Maybe the switch is shorting due to the sagging door. It might be making contact at a wierd angle, causing the end of the switch (inside the dash area, the part you can't see) to touch ground.
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
