cluster question
I've been planning on changing out my cluster for 2 reasons, one it stucks at times on the speedo and tach, 2nd to add the tranny temp. I tried to search and couldnt find any real info on this.
My question is what yrs/models of truck/suvs clusters with the tranny temp will fit my truck without causing the airbag light? I can get the ones from jp but have seen some pretty cheap ones on ebay..most under 150. with the temp guage, but not sure of the years/models, types(2500,3500, etc)
Thanks in advance
Any cluster for years 99-02 will fit/work in your truck...but unless it is specifically modified for a 99, the airbag light will show constantly. So if those on Ebay don't mention it, you can assume it hasn't been modified. Here is another site that sells clusters specifically for 99's...good luck.
Extreme Factory FX
    Brendan C
    Brendan C
  • Who's Online   5 Members, 0 Anonymous, 1,119 Guests (See full list)
