undercoat wheelwells
Suburbans and Tahoe have the plastic liners. I like these because they are less likely to flake, etc.....although they will split and crack if really beat on.
I have to wonder if Line-x or some other bedliner would be a good solution for the trucks.
  • 1 month later...
My dually is in getting done today by Rhinolinings...the installer called to say the will have it completed by noon tomorrow. I'll post pics. I had the rockers sprayed as well as the wheelwells. He said it was done but they had the demasking and final prep left to do...said it looked very sharp!
Yes, pictures are below of the rocker panels...I coudn't get up into the wheel wells with the camera but suffice it to say the did a very crappy job. They refunded me the charge for that as the installer said they couldn't get the entire wheel well as the wand sprayer they use is 3' long...very crappy job. Where you look at the well from the side of the wheel, it looked great but if you lay on your back and look up, you can see where they didn't even get the inside of the wheel well by the "outside" of the truck. I will be picking up the spray at Napa and do the rest myself as I should have. However, the rockers came out perfect.
    overspeed
    overspeed
  • Who's Online   1 Member, 0 Anonymous, 431 Guests (See full list)
