Weld Wheels
I just got a used set of 5 weld wheels that I purchased problem is they are just a bit to wide for what I want. they are 16X10 6lug for a GM truck somthing like 4.5" back spacing. I have pics if anyone is intrested. I would take the same wheels in a 17X8 or somthing in that size and value as a trade. Otherwise looking for best offer. Wheels are located in the Dallas/FT area. thanks, Rob.
