Hi everyone, my first post here. looks like a great site. Ive got (7 days now) a 2003 S-10 extreme yellow with black stripes. Found the RPO code site for the S-10 but even on that list im still missing about 12 codes that were not on the GM list. got any ideas where to go fine the ones im missing.
john :cheers:
The mystery codes sometimes are just that. Some are build plant. Some are promotional codes to the dealer for rebaters and such. And some seem to just be there to take up space. Post up the one's you don't know and sombody may be able to help. Expect a few to still be elusive.
PM them to me. Once I get the Tech info re-installed (I just upgraded to XP with a clean install), I can look them up in there and see if we can get the mystery resolved. The other route to go is to ask your local dealer to punch in your VIN and print out the list. I had mine do that when I bought my truck last year.
  • 1 month later...
